  • What To Look For When Shopping For An Inflatable SUP Board
An inflatable SUP board, or iSUP, is the ultimate option for those seeking a lightweight and highly portable paddling vessel. These inflatable boards are great for beginners, as they are easy to learn on and are often affordable. They are also a great vessel to add to any paddler’s arsenal. Before you buy an iSUP, however, there are many factors to consider in detail to ensure you buy the perfect board for your needs.
When shopping for an iSUP, always look for a board with proven stability and a design that suits your specific needs. Choose a board that can support your weight and your gear. Check what is included in the iSUP kit, as some kits come fully equipped, while others only include the board and fins. Try to avoid heavy iSUPs, as they are more challenging to transport.
Buying an iSUP is always a good idea. These vessels are affordable, portable, and an endless source of fun. But with so many iSUP brands, designs, and price points, choosing the right board for you can be a struggle. To ensure you select the perfect iSUP for your needs, read the list below of what to look for when shopping for an inflatable SUP board.
11 Things To Look For When Shopping For An Inflatable SUP Board
1. Board Stability
One of the most important qualities to seek out in an iSUP is stability. Since these vessels are much lighter than solid boards, many iSUPs are difficult to balance on, especially if you are a beginner or a larger paddler.
When choosing a SUP board, search for brands with proven stability and built-in balancing technology. Unless you plan to race with your inflatable board, consider a wider board and prioritize stability to ensure an enjoyable, stress-free paddling experience.
2. Total Weight Of Kit
Always look at the total weight of the iSUP kit when you’re shopping for a new inflatable vessel. If you plan to carry this kit on your back, then you want something lighter, ideally less than 25 pounds.
If a kit is very heavy, it may be more cumbersome to carry, which might defeat the purpose of owning an iSUP. A vessel that is too light, however, might not be able to support heavier paddlers. Finding the perfect balance is key.
3. Portability
The most significant benefit of an iSUP is its portability. Therefore, you must ensure the iSUP you buy is easy to transport and seamless to set up. Look for an iSUP that includes a durable backpack or gear bag. Find a board that is easy to roll up, inflate, deflate, and fit into the bag.
Opt for boards with fins that lock into place easily and come with an electric SUP pump or a portable, easy-to-use pump. The easier a board is to transport, inflate, and set up, the happier you will be with your purchase.
4. Design And Intended Purpose
While shopping for the perfect iSUP, you must always have your intended uses in mind. Remember that not every board is right for every paddler. If, for example, you want to use your iSUP for SUP yoga, then you should choose a wide, thick board with proven stability and superior balance.
If, however, you want a board that can move fast and race, a long, narrow board with great tracking is ideal. Opt for a wider vessel, as these tend to have better balance and more versatile uses.
5. Fin Quality
Quality fins are essential on an iSUP, as they provide crucial maneuverability and tracking. Since these vessels are so light, fins play a vital role in navigation and control. Opt for a board with proven-quality fins to improve maneuverability and stability.
Furthermore, look for iSUPs with intuitive, easy-lock fins. You don’t want to have to worry about fins getting stuck on your iSUP or taking a long time to attach. Poorly designed fins can be a real headache - you must choose quality whenever possible.
6. Handles And Ease Of Transport
Even though iSUPs are lighter than most other paddling vessels, you want to ensure yours is as easy to transport to and from launch locations. Look for iSUPs with multiple handles, as this will make carrying the board much easier.
Inspect the handles and look for durable, padded ones, as these will make things more comfortable for you.
7. Durable Materials And Stitching
When you search for an inflatable vessel, you should buy something that’s built to last. A poorly made iSUP can leak and rip, rendering the board unusable. Opt for boards made of very durable PVC (military-grade is usually best). Stitching is also essential. Read reviews and details about the stitching technology used for the board you are interested in.
8. Bungees And Storage Capacity
Having secure storage on any paddleboard is crucial. You need a place to store your dry bag, water, first aid kit, and other essentials. Unfortunately, some iSUPs lack the storage and bungees found in other boards.
Always ensure the board you are interested in has ample storage for your needs. If you only plan on casual day paddling, you won’t need too much. If, however, you plan to use your iSUP as a touring kayak on multi-day trips, you’ll want to prioritize storage space.
9. What’s Included In The Kit?
As you shop for the perfect iSUP, you should pay close attention to what is included in each kit. Some iSUPs only include the board and detachable fins. Others are sold as complete kits and include a leash, adjustable paddle, pump, and backpack.
If you are new to paddling or are buying a SUP as a gift for someone, consider purchasing a complete kit. This is a great way to get a full bundle at a reasonable price. If you already have a leash, pump, and other SUP accessories, you can focus your attention more on the board itself.
10. Check Total Volume and Weight Limitations
SUP boards can’t handle as much weight as other paddling vessels, and iSUPs in particular have weight limitations worth noting. Ensure the board you are thinking about buying can withstand not only your weight, but also the weight of your gear.
The total volume of the iSUP should be significantly more than your weight. As a general rule, your weight in kilograms should be less than half the total volume of the board, in liters.
11. Comfortable And Quality Deck Pads
The decking on a SUP board is where your feet, knees, and other parts of your body spend the most time. Therefore, you must purchase a board with high-quality deck pads. Look for decking that is soft and comfortable while also providing good grip. Avoid padding made of cheap material or slippery decking.
