Razor Edge Pro 2 Review
Razor Edge Pro 2 - Paddling 1
Razor’s Edge Pro series doesn’t just improve upon the inflatable kayak – it resets expectations. It trades the usual softness for a rigidity that comes surprisingly close to a hardshell, and swaps bulk for speed and precision on the water. The slim panel drop-stitch construction frees up more usable interior space, while setup is quick, pack-down quicker, and everything you need stows neatly into a wheeled travel bag.
This isn’t just a better inflatable – it’s a genuine paradigm shift.
The Drop-Stitch Advantage
Like the Edge Pro 1 we previously tested, the standout feature of the Edge Pro 2 is Razor’s clever use of drop-stitch technology, which allows it to construct an inflatable kayak that looks, feels and performs more like a hardshell.
Razor Edge Pro 2 Construction
Thousands of high-strength filaments connect top and bottom layers of three distinct panels, creating a structure with defined shape and impressive rigidity. These panels aren’t flat or thick, but they do add subtle angles to more closely resemble a hardshell’s profile. It’s not just form, but function. The Edge Pro 2 delivers a noticeably stiffer, more performance-oriented ride than most inflatables can deliver.
Durability is above the norm. The exterior is reinforced with a mesh layer and finished with high-density, 1000-denier PVC. Nose and tail cones add additional reinforcement.
The entire 16-foot, 1-inch-long, 28-inch-wide kayak – including seats, paddle sections, fins and footrests – pack into a 35 x 21 x 17-inch wheeled backpack for transport. Pushing 50 pounds when loaded with kayak and accessories, it’s heavier than some, but integrated wheels make it manageable over paved or hard-packed ground.
Razor Edge Pro 2 - Fin
Setup is refreshingly straightforward, just as on the Edge Pro 1. Unroll the deflated kayak, inflate the three separate panels (two topside, one below) via a trio of inflation valves, attach seats via Velcro strips, and secure footrests. With an electric pump you can be done in under 10 minutes. Seat backs and footrests adjust via straps; clip the former to D-rings on the floor, the latter to looped straps sewn along the perimeter. Hardware is all marine-grade stainless steel. Once inflated, the approximately 45-pound kayak has grab handles at bow and stern to make for a relatively easy carry to the water.
Our test unit came with a pair of carbon-fiber paddles that break down into four pieces for transport. They’re lighter (1.8 pounds) than Razor’s aluminum or fiberglass versions, although a few of our testers wished they were a little longer than the standard 88.5 inches. Slide the single 8.5-inch fin into the fin box and you’re ready to hit the water.
Rare Air
Razor Edge Pro 2 Seat
Take a seat in either cockpit of the Razor Edge Pro 2 and it’s a relatively comfortable perch. The perimeter coaming has a soft touch, which will be appreciated by users when knees rub against it.
Storage topside includes two bungeed sections ready to keep items close at hand. Don’t overlook the potential of the spacious interior for larger items. Stash a gear bag fore or aft and it’s out of the elements. Spray skirts can be added to extend the season into cooler months or keep water at bay should you venture into rougher or larger waters.
Razor Edge Pro 2 - Paddling Rear
On the water, the Edge Pro 2 delivers performance that stands out in the inflatable category. Its sleek PVC hull and pointed bow translate into a fast, efficient glide, while the single 8.5-inch fin provides straight-line tracking. At the same time, it’s very responsive to paddle input, displaying an agile nature that allows us to easily carve turns and navigate tighter, more technical waters.
Stability is equally impressive, for both experienced and newer paddlers. We never felt tippy, even when intentionally rocking the boat, and rougher waters did little to diminish our confidence.
Final Thoughts
The Razor Edge Pro 2 has a lot to offer prospective buyers. Its use of drop-stitch construction is innovative, though it does result in a slightly heavier weight. Still, that same weight may also add to the kayak’s solid presence in the water. At $1,749 it skews toward the top-end of the market in terms of pricing, but that is to be expected from a premium product.
Razor Edge Pro 2 Profile
This isn’t a kayak you buy because you have to factor in convenience of transport or storage. It’s an impressive ride that just happens to tick those boxes. It truly is an inflatable that looks, feels – and performs – much like a hardshell kayak.
Like we said, a paradigm shift. Not to mention one heck of a lot of fun.
Photo by Andrew Graus Standup paddleboards can be heaven out on the water, but a little hellish back on…
