Top Tips For New Kayakers
If you’re ready to get serious about kayaking, then you’re probably eager to buy some gear. After a quick look online, you will quickly find that there are endless kayak types and dozens of ways people use these paddling vessels. Before you spend thousands of dollars on this new hobby, it’s crucial you know what equipment is essential for all kayak enthusiasts, and what type of kayak is right for you.
The most important and first piece of equipment you should buy is a PFD. Buy a kayak-specific PFD with a wide range of motion. Before purchasing a kayak, determine the type of kayaking you want to do and what water conditions you plan to paddle in. Short and flat-hulled kayaks are better for rapids and rivers, while long and rounder hulls have more speed and better glide.
If you’re new to kayaking, the video above is a great way to dip your toes into understanding this enjoyable yet complex water sport. There’s a lot of information to digest in this six-minute rundown, so we’ve elaborated on the main points below to help you absorb the information more easily.
Top Tips For New Kayakers And Key Takeaways
1. Buy The Right PFD, And Always Wear It
The most important takeaway from the video above is the importance of not only wearing a PFD but also choosing the perfect PFD for your kayaking needs. If kayaking is your paddling preference, then opt for a kayak-specific PFD.
These PFDs usually have lots of free space around the shoulders and often have a high mesh back. This allows a great range of motion and prevents you from chafing your arms against your PFD while paddling. It also makes it easier to lean back in your kayak seat.
Front pockets are also a great feature, as they can store useful items like a whistle, chapstick, and even a GPS.
2. Know How To Sit In Your Kayak
There are many different kayak designs, which means that you’ll sit in a kayak a bit differently depending on its layout. It’s best to avoid sitting in a kayak in a reclined position and never completely extend your legs.
To improve posture, you need to have the proper positioning in your kayak. Usually, this means a bend in the knee and an upright stance. This will activate your core and lower body, and thus spread the physical burden you endure while paddling. Otherwise, you’ll end up using only your upper body and tire quickly. Bad posture can also result in paddling injuries.
3. Adjust Your Kayak To Make Paddling Easier
Almost every kayak is adjustable. Often, your seat, foot braces, and pedals should be moved into a position that suits your body. Ensure you know how to adjust them to ensure a comfortable and successful paddle.
Remember, not all kayaks are meant for all people. Choose a vessel that is compatible with your height, build, and weight. Always check the weight rating on a kayak before buying it. Factor in not only your weight, but also factor in the weight of the gear you’ll carry with you.
3. Choose The Right Kayak For Your Paddling Conditions
Choosing the right kayak requires a lot of thought and understanding of exactly what type of paddling you plan on doing. You can kayak in raging rapids or on placid lakes. Know what type of kayaking you plan to do, and the water conditions you plan to launch into.
For those looking for long and tranquil rides, you can opt for longer touring kayaks, and fun sit-on-top kayaks if you plan to stay close to shore. If you plan to hit the rapids and navigate serpentine rivers, shorter kayaks are best.
4. What Kayak Shapes And Sizes Translate To On The Water
As a general rule, the longer the kayak, the better it glides and and faster it will move. Shorter kayaks lack speed, but they can turn much more effectively.
When it comes to hull design, remember that flat means easy to turn, and round means good tracking and better glide. Don’t choose a kayak because it looks “cool,” but instead choose one that will best serve you.
5. Make Sure Your Kayak Floats
This sounds like a no-brainer, but you want a kayak that floats. Not all kayaks are equally buoyant, especially when a kayak fills with water. Sit-on-top kayaks are great for those who are interested in kayaking short distances, as they self-drain and are filled with air.
Look for a kayak with at least two sealed bulkheads (one in the front and one in the back), as this will make your kayak more buoyant, even when filled with water. Alternatively, purchase float bags to ensure less buoyant paddling vessels continue to float, even when filled with water.
