Tips For Picking The Right Anchor For Your Paddling Vessel
The main function of a paddling vessel is to move on the water, but sometimes you want to stay still while floating in your kayak, canoe, or SUP board. Whether you’re taking a snack break or snorkeling at nearby coral reefs, there are all sorts of reasons why owning an anchor for your paddling vessel is essential. Picking the perfect anchor for your needs, however, is harder than you might think.
As you search for the ideal anchor for your paddling vessel, you must consider factors like your boat’s size and weight, and the typical conditions on the seabed where you paddle. Other important factors include your typical intended use, weather, and current conditions. Choose an anchor that’s the right weight, rust-proof, and ideally both portable and collapsible. Remember to consider your anchor line, buoy, and storage when selecting an anchor.
There is no one perfect anchor for all paddling vessels. Instead, there are various factors you need to think about when you choose which anchor is best for you and your paddling needs. To help you make the right decision for your vessel, read the list of factors to consider when buying a paddling vessel anchor listed below.
Factors To Consider When Selecting A Paddling Vessel Anchor
1. Vessel Size
One of the most important variables you must consider when selecting an anchor is your vessel's size and weight. Typically, the larger and heavier your paddling vessel, the heavier your anchor needs to be to keep it in place.
Therefore, if you have a lightweight and inflatable vessel, you can get away with a very light anchor. Larger touring kayaks loaded with gear, however, should be a bit heavier than a typical kayak anchor.
2. Sea Bed Type
You also need to think about where you are dropping your anchor before buying one. The sea floor or lake bottom can have a major impact on the type of anchor you purchase. For example, if you paddle in regions with sandy or muddy bottoms, then a heavier mushroom-type anchor should work well to keep your boat in place.
If, however, you paddle on rocky bottom, use a grapnel anchor or one with a claw. These shapes help hook the anchor to the bottom, keeping your boat in place and allowing you to use a lighter anchor.
If you paddle in various conditions, then opt for a versatile shape. The key is knowing what the bottom looks like, as this will help you make a more informed decision.
3. Intended Use
Another factor you need to consider as you shop for the perfect paddling anchor is when you will use it and for how long. If, for example, you are buying it just in case you want to take a quick dip away from your SUP board, you can be fairly flexible.
If, however, you plan to anchor a kayak in a river or bay overnight, then you’ll want to buy something much more reliable to keep your vessel still in moving water. Consider how many hours you plan to leave your vessel unattended and how frequently you intend to do so.
4. Don’t Forget About Chain, Buoy, And Rope
When you purchase an anchor set for your paddling vessel, you must always remember that an anchor is only as strong as the chain and rope it’s connected to. Therefore, when you buy an anchor, ensure you are also purchasing a quality chain and rope.
Remember that both rope and chain must be replaced over time, as they weaken. An anchor buoy is also a good idea, as it provides additional safety.
5. Consider Collapsible And Easy-To-Stowe Options
Unlike large boat anchors that are bulky and difficult to store, paddling anchors are often small and compact. Whenever possible, search for an anchor that collapses or is small and easy to tuck into one of your vessel’s storage spots.
Remember, the larger and heavier an anchor is, the more challenging it will be to stow. Look for an anchor that collapses into a bag with the anchor line, as this makes carrying an anchor much easier.
6. Think About Typical Weather And Current Conditions
It’s easy to keep a boat in place when there’s no current or wind. But on a windy day, or in waters with strong currents, your anchor must work overtime to keep your vessel in place. Therefore, you have to factor in typical weather and current conditions when you shop for an anchor.
If you experience frequent wind, buy a stronger or slightly heavier anchor. If you often find yourself wanting to anchor in areas with current, ensure you have an anchor that stays safely on the ground without dragging.
Attributes To Look For In The Perfect Paddling Anchor
1. Portability
Perhaps the top attribute to look for in a paddling anchor is portability. The easier it is to carry your anchor, the more likely you are to bring it along with you. Many anchors are collapsible, making them easy to store in a small bag along with your anchor line. Whenever possible, buy a small, easy-to-carry anchor that suits your needs.
2. Avoid Anchors That Will Scratch Or Puncture Your Vessel
Paddling vessels are typically more vulnerable to scratches and damage than larger boats. Therefore, you must pay close attention to the shape and materials your anchor is made of. Avoid buying an anchor with sharp metal edges that are not protected. Instead, choose an anchor that won’t scratch, puncture, or otherwise damage your vessel.
3. Look For Rust-Proof Materials
When you buy an anchor, resist the temptation to buy the cheapest option. Very cheap anchors are often less durable and less rust-resistant. Instead, opt for anchors made by reputable companies that have proven durability standards. Read reviews when buying an anchor from an online retailer to confirm you are buying an anchor that’s built to last.
4. Correct Weight And Size For Your Needs
When you buy an anchor, you don’t want to go too light or too heavy. Typically, you don’t want an anchor that’s more than five pounds, unless you have a heavy paddling vessel and are anchoring in particularly challenging conditions.
Take the time to factor in the size and weight of your paddling vessel, along with all the factors listed above. Taking these variables into consideration should help you choose an anchor that is the ideal weight and size for you.
5. Choose The Correct Design For Your Paddling Needs
There are many types of anchors you can choose from. They come in various shapes and designs, which can make choosing the perfect anchor seem daunting. Never choose an anchor at random.
Instead, choose an anchor design that matches your paddling needs and one that will work best in the waters you typically paddle in.
