Abdominal Workout for Paddlers
Paddling.net continues the series of specific exercises for paddlers, targeting a different muscle group every month. Each exercise in the series, will be a part of a full body routine to be done three days a week. It's a great routine for athletes in almost any sport. For the paddler, it will build endurance, muscle, balance and coordination.
Last time we focused on the arms, and this month, we'll focus on exercises to build up the abdominals:
Knee Hangs - Basic (strength, balance, muscle tone)
Muscles Used: Obliques
Used In: J Leans, C Leans, Rolls, Recover Strokes, Sweep, low brace and bow rudder turns.
Sets: 3
Reps: 20
This is a great abdominal exercise designed for the kayaker! It will train the obliques for use in all kayak leaning and edging. It will also quicken the hip snap response.
Begin with the feet slightly wider than shoulder width apart. You can use a paddle, broomstick or dowel for this exercise.
Holding the paddle over head and with a wide grip, raise one knee and hip by flexing the oblique muscles. Hold the position and squeeze the muscles in your side. Go for the burn! Alternate sides, holding and flexing. Count both sides as one set.
Bench Crunches - Isolation (strength, balance, muscle tone)
Muscles Used: Upper & Lower Abdominals
Used In: All paddling manuevers
Sets: 3
Reps: 20
Ab crunches have been around for a long time but this exercise develops balance as well as ab strength and tone.
Using a flat bench, lay back with the hips on the edge of the very end. Keep the knees and feet together with a slight bend in the knees.
Lower the legs and stretch the abdominals while keeping the shoulders on the pad.
With the hands behind your head, raise the shoulders and legs at the same time. Flex the abs and "crunch" the chest to the knees.
Use the muscles of the abs to crunch! Don't raise the shoulders off the pad by pulling with your arms.
Take your time to maintain balance while working the abs.
These great abdominal exercises, when added to your full body routine will help build muscle and stamina.
THE SEA KAYAKER.COM
