12 Product Ideas for Kayak Storage
Whether you have a winter offseason or not, proper boat storage is important when not in use. Fortunately, there are storage systems designed for every imaginable vertical or horizontal nook and cranny. There are kayak wall racks, freestanding racks, protective covers, hoister systems, ceiling racks, and much more. Check out these 12 different storage ideas below or check the entire Kayak Storage Buyers Guide to see them all and read reviews.
12 Products for Kayak Storage
- FS Rack™ 2 Kayak & 2+ SUP Storage Rack by Malone Auto Racks
- JAY Wall Mount Rack by Suspenz Storage & Transport
- EZ 3-Boat Free Standing Rack by Suspenz Storage & Transport
- Hoister Storage System — 75-200 lb Load by Harken, Inc.
- KC-103 Dual Kayak Rack by Sparehand Paddlesports
- Buddy Kayak Cover by Danuu Paddle Gear
- Big EZ Wall Mount Rack by Suspenz Storage & Transport
- Kayak Hanger by Salamander Paddle Gear
- SlingOne Single Kayak Hoist Storage System by Malone Auto Racks
- Sherpak Hoist by Seattle Sports
- Ceiling Rack by Suspenz Storage & Transport
- Yak Wrap Playpen by Salamander Paddle Gear
1. FS Rack™ 2 Kayak & 2+ SUP Storage Rack
The MPG334 is a two kayak + two SUP self-standing boat storage rack. Comes complete with frame, hardware, J-Style Holders, SUP-Style Holders and lower frame kayak blocks. Built with powder coated high load steel, this package is easy to assemble and will last for years.
- Two kayak + two SUP storage capacity
- Heavy duty 1.25" square tube construction
- Powder coated for inside or outside installation
- Six independent adjustable frame levelers
- One set of MPG339 lower frame kayak blocks
- One set of MPG320 J-Style padded holders
- One set of MPG325 SUP-Style padded holders
- Corrosion resistant hardware with installation tool
- Lifetime Limited Warranty
FS Rack™ 2 Kayak & 2+ SUP Storage Rack Reviews
No one has submitted a review yet for the FS Rack™ 2 Kayak & 2+ SUP Storage Rack. Please help out the community and share your experience!
2. JAY Wall Mount Rack
The BEST way to store your boat is to suspend it on straps so there are NO PRESSURE POINTS, it never touches a hard surface! This JAY Rack will cradle your boat and distribute its weight evenly. Included in box: 2 JAY Arms with Safety Straps & Wall Mounting Hardware.
- Extends 22" from the wall, Height: 26”
- Boat rest on the exclusive CSS (Cradling Strap System) – No pressure points; protects against hull distortion
- Store kayaks on their SIDE at its strongest point
- Adjustable straps to suspend your kayak or SUP correctly
- Module arm that can also attach to Free-Standing rack
- Stores boats up to 125 lbs.
JAY Wall Mount Rack Reviews
I purchased the Suspenz…
Very Good racks, nice wide…
3. EZ 3-Boat Free Standing Rack
The EZ 3-Boat Free-Standing Solution includes Safety Straps! Economical Free-Standing Kayak-Canoe Storage Racks. Boats rest on Canvas Covered foam padding and a powder coated steel frame for indoor and outdoor use. Leveling feet & optional anchoring hardware are included. Protects boats from abrasions, dents and hull distortion. Expand this EZ 3-Boat Free-Standing Rack to hold kayaks on back-side. Reinforced safety straps securely hold your boats in place. Saves storage space by angling the boat and protects hulls at the same time.
Kit includes everything to rack 3 kayaks: 3 Pair of EZ Padded Arms with safety straps & 3-Boat Frame with leveling feet and anchoring hardware
Marine Grade BLACK for use in salt water environments is powder-coated steel with galvanized coating and stainless steel hardware. $544.80
- More information about EZ 3-Boat Free Standing Rack
- Holds up to 100 lbs. per boat
- Indoor or Outdoor use
- Assembled rack dimensions: Footprint: 24" x 24" per tower Height: 76"
EZ 3-Boat Free Standing Rack Reviews
I got tired of having my…
4. Hoister Storage System — 75-200 lb Load
- More information about Hoister Storage System — 75-200 lb Load
- View all products from Harken, Inc.
- Maximum Load: 200 lbs.
- Minimum Load: 75 lbs.
- 4 Lifting Points; up to 200 pounds
- Mechanical Advantage 8:1
Hoister Storage System — 75-200 lb Load Reviews
I bought the 90 lb system and…
I purchased the 2 point…
These are the way to go, if…
5. KC-103 Dual Kayak Rack
The Sparehand KC-103 “Catalina” Freestanding Double Kayak or Canoe Storage Rack has a 175-pound maximum weight capacity and is a convenient storage solution for any style of kayak or SUP. Constructed of durable steel with a black finish, this unit stores a maximum of (2) kayaks or SUPs off the ground and out of the way. The KC-103 can be used in all weather conditions for indoor and outdoor use and features a rust resistant coating. This storage rack has an exclusive flat top cradle that lets you store a larger kayak or canoe on the top level. The rack’s sturdy 48-inch by 46-inch base prevents the rack from tipping over and keeps even the heaviest kayak stored securely. This heavy-duty rack fit kayaks and canoes with a length up to 20-feet and a hull size up to 36-inches wide and 18-inches deep. Sparehand’s unique and accessible design saves space, while making it easy for you to grab and store kayaks and SUPs. This unit is quick to assemble with no drilling into walls or ceilings. The Sparehand KC-103 “Catalina” Freestanding Catalina Double Kayak or Canoe Storage Rack comes with a 1-year limited manufacturer’s warranty to protect against defects in material and workmanship. Sparehand Systems is dedicated to innovation and simplicity and specializes in high-quality lifestyle and sports products.
- More information about KC-103 Dual Kayak Rack
- Maximum weight capacity of 175-pounds and stores virtually any style of kayak or SUP
- Stores up to (2) kayaks or SUPs off the ground and out of the way
- Light weight and easy to move around with rust resistant coatings inside and out
- Constructed of durable steel with Powder Coat Finish
- Recommended for indoor use
- Maybe used for outdoor under certain weather and climate conditions with proper care and protections
- Caster Wheels (sold separately) can be added to this system
KC-103 Dual Kayak Rack Reviews
No one has submitted a review yet for the KC-103 Dual Kayak Rack. Please help out the community and share your experience!
6. Buddy Kayak Cover
Danuu Covers extend the life of your craft by protecting it from the elements and harmful UV rays! Our covers are made with a standard of quality that is higher than anyone else and are shown repeatedly to be the best in their class.
These covers are durable and convenient, simply drape it over your craft and cinch the straps for a custom fit. Perfect storage solution for those without the ability to keep their boat inside a garage or shed - also provides unsurpassed protection while traveling.
- More information about Buddy Kayak Cover
- View all products from Danuu Paddle Gear
- Fully Adjustable for Custom Fit
- V-loops along edges for additional strapping points100% Polyester (UV-resistant)
- Reinforced seams and cross stitching at all pressure points
- Light weight fabric with high tech meshing - durable and convenient
- No metal parts that rust
- Easy on/off design
- Water repellent
- Attached Flag Bag adds safety in transport/doubles as convenient storage
- One-year warranty on manufacturing defects
Buddy Kayak Cover Reviews
My kayak being just under 16…
My new cover replaces my…
7. Big EZ Wall Mount Rack
Watercraft rests on nylon covered foam pad. Stores boats & boards on their side at their strongest point. Adjustable safety straps hold your boat securely in place. UV protected straps, fabrics and plastic parts. Includes 2 Big EZ Arms with Safety Straps & Mounting Hardware.
Available in Marine Grade (Black) - $104.95
- More information about Big EZ Wall Mount Rack
- Compatible with Suspenz Free-Standing Storage Systems
- Extends 28” from the wall
- Holds up to 150 lbs.
Big EZ Wall Mount Rack Reviews
No one has submitted a review yet for the Big EZ Wall Mount Rack. Please help out the community and share your experience!
8. Kayak Hanger
This simple yet very effective kayak hanger system allows you to store boat and paddle off the floor and out of the way, creating additional space for even more toys!
- More information about Kayak Hanger
- View all products from Salamander Paddle Gear
Kayak Hanger Reviews
No one has submitted a review yet for the Kayak Hanger. Please help out the community and share your experience!
9. SlingOne Single Kayak Hoist Storage System
Malone's most affordable kayak hanging storage system, the SlingOne™ is perfect to store a single kayak. Suspend from the ceiling or attach this system to a wall. Easily installs in minutes.
- Simple no hassle mounting
- Heavy duty 1.5" webbing
- Easy to use quick connect carabiners
- Adjustable buckles allow for varying kayak widths
- One Year Limited Warranty
SlingOne Single Kayak Hoist Storage System Reviews
This system works well and…
10. Sherpak Hoist
Use this heavy-duty hoist for lifting and suspending bikes,storage boxes or boats to the ceiling of your garage, up off the floor.
- More information about Sherpak Hoist
- Mounting hardware included
- Maximum Load Capacity: 100lb
Sherpak Hoist Reviews
I have three of these hoist…
11. Ceiling Rack
Go "off the wall" with this genius yet simple ceiling rack. The open ends of the dual L-shape design provide convenient access to your watercraft while storing them safely out of the way. Rack arms adjust vertically to accommodate thicker kayaks and thinner boards together.
Included in box: 2 Ceiling Posts 4 Arms Ceiling Mounting Hardware
- More information about Ceiling Rack
- Adjustable vertical spacing
- Can be adjusted to use one or both sides of rack
- Distributes the weight of your kayak, canoe or SUP evenly based on its length by using the Spacing Chart
- Indoor & Outdoor use
- Stores boats up to 100 lbs
- Arms extend 32"
- Ceiling post extends down 19"
- Can be expanded with the Ceiling Expansion Rack
Ceiling Rack Reviews
No one has submitted a review yet for the Ceiling Rack. Please help out the community and share your experience!
12. Yak Wrap Playpen
Salamander Yak Wrap Playpen boat bag is built tough to help protect and conceal your boat during travel. The Playpen has a 72" circumference at widest point and gradually steps down to 56*" circumference 15" from bow & stern. Length of Bag is 7'.
- More information about Yak Wrap Playpen
- Rugged 600 Denier poly-cloth exterior with reinforced bow and stern cones
- Webbing grab loop and balanced carrying handle
- Self-repairing #7 coil zipper
- ID pocket
Yak Wrap Playpen Reviews
No one has submitted a review yet for the Yak Wrap Playpen. Please help out the community and share your experience!
For some of us, storing our canoe or kayak is as simple as dropping it off alongside the garage or…
Canoe storage is critical, not only for the offseason to protect your boat, but because space is limited…
